Results 1 to 6 of 6
    Mar 2009
    aylesbury
    throttle bodie injector possitions?
    I am in the process of installing a set of hayabusa throttle bodies to my f7r powered 5 but am having a bit of a !
    does anyone know if it is okay to keep the injectors in the head as oe or should they go in the actual throttle bodies themselves?
    thanks peeps!
    Ireland Area Rep robx1r's Avatar
    Sep 2009
    meath
    Re: throttle bodie injector possitions?
    you want the fuel to be as atomised as possible, as in a fine a spray
    I've seen a twin injector setup on a throttle bodied F7R before, they had a set of standard injectors in the head for all the low down fueling but after a certain amount of throttle they switch off and a second set mounted pointing down the throttle bodies cut in
    If the throttle bodies have the injectors in them already I would prob fit them there, could make some plugs for the head and plug the original injector holes up
    Kent
    Can't use 'standard size' injectors in the busa bodies, you have to use pico injectors to go in them.
    Btcc cars had 8 injector setups, only really worked well if they were directed into the trumpets.
    Non-member rs250nut's Avatar
    Quote Originally Posted by Matt@CodeRedMotorsports View Post
    F1 cars work in a similar way with top feed injectors
