Results 1 to 18 of 18
    Apr 2014
    Standard Springs? Where?!?
    Where can I get them new?
    Mikes gone quiet so where else? CGB has none either.
    Are there any on ebay that aren't just Campus springs?
    Getting annoyed now...
    Norwich
    Re: Standard Springs? Where?!?
    Might be some on ebay, to be honest people that fit new standard springs end up with a car that looks rather 'jacked up' at the front even after it has settled. Best bet would be to buy some new good quality -30 or -35mm lowering springs. Old standard springs will become compressed over time so will look lower .
    Apr 2014
    Yeah I get what ya saying. I'm seeing ads for YKB springs which are a decent make and seem to be specific to the GTT but it's still a bit of a gamble.
    I did see someone say that they had out -20mm springs but I can't see any anywhere! That would be OK.
    Apr 2014
    Ok. Update. KYB list a specific spring for 87-91 GTT.
    And I've spoken to Unipart who also have a specific listing.(I forget the brand!) Call back Monday.
    Rang renault. They list some, but need the colour codes! Two colours are showing as no longer available.
    Trader
    GT Turbo Spares co.uk
    South East Regional Rep
    phase i 16 v turbo's Avatar
    Jan 2001
    Morden
    Got several sets on cars just need to get them off. They will need media blasting and powered coating to look good again. Have had a few days working on my own cars so not been on line much.
    Thanks Mike
    Apr 2014
    Thanks Mike. Current thinking is to just get a set if lowering springs and get OE springs sorted over the winter.
    Oct 2012
    A
    Quote Originally Posted by Matt_S View Post
    Get a stiffer suspension Matt. OE springs are pony. My advice is get some konis off the club shop. I've had OE and konis and the difference is massive.
    Non-member Goobie's Avatar
    Mar 2002
    East Sussex
    This.
    Any new standard rideheight springs that are available now are the wrong length i.e. Too high. If you want o.e height buy second hand original springs.
    Apr 2014
    This is true. But I can't find any at the moment that can be fitted this week!
    Thanks for the comments.
    Apr 2014
    Ok,
    I've spoken to a company that can make springs. Any spec you want. So I'm thinking of getting a second hand std spring and having it measured up and then reproduced in NEW steel and powder coated black.
    This could be done for less than £100 a pair I reckon. When you consider that second hand springs are £50 a set plus delivery from one of the two main suppliers we use and then they need blasting and coating, I think it's a good option. New springs that aren't 20+ years old.
    Would there be any takers if I was to get a few sets made up while I'm at it?
    Non-member Matty's Avatar
    Aug 2014
    Longwick, Bucks
    i could be interested. i need to know whether mine is standard height or not tough. it looks a bit to high i n my opinion.does anyone know the factory height to the bottom of the arch to ground?
    Apr 2014
    I had Matt with the std white one measure his for me...
    Front - 59cm
    Rear - 55cm
    Put a pic up to show us yours. I'll add pics of KYBs and the Apex -35mm that are on there now
    Apr 2014
    Only pics I have on the KYBs are from the for sale ad...
    Lowered...
    What are the poundage of the original springs? I assume the manufacturers have asked you that already?
    Edit - that first pic of the white GTT looks like it's on the wrong springs (i.e. too high), like Brigsy says above.
    Non-member Jimmy5's Avatar
    Oct 2010
    Standard height springs on my five had the green and grey paint blobs on them when cleaned up. Just had them powder coated the other day.
    Apr 2014
    They are KYB springs listed for the GTT. and yes, as said it looks too high. There was a LOT of tension on them when they were bolted in.
    Aug 2014
    Longwick, Bucks
    This is my ride height.
