1 Attachment(s)
What am I missing/what do I need?
Looking for some advice if possible.
Had a good look over my car over the weekend and noticed a few minor issues that I hope will be easy to fix...
First pic is of the bottom centre of the window seal - looks like I've lost a cover of some kind. Any ideas what part it is and what it should look like normally.
Second and third pics are of the seals on the fixtures on the rear window. I've lost some and some are on their last legs. Any chance these are still available and if so what am I looking for?
1 Attachment(s)
Re: What am I missing/what do I need?
1 Attachment(s)
There's a little plastic cover that goes between the windscreen rubber. Try gt turbo spares or CGB for replacements.
Thanks.
They have it as a t-piece which I assume is the right thing. There are 35 and 50mm versions - is one ph1 and one ph2?
get the bigger one it will fit fine, as for the window seals I got mine from CGB, easy to replace and looks so much better, also stops water getting in...
clarkey21
Cheers - are the rear seals the ones in the link below? Just the ones in the CGB pic don't look like I thought they did?
The rear window seals are available still. But the fronts aren't.
Also, think you can get then screen join cover from renault.
