gordini turbo carb
does anyone have to hand the specs and jet sies of the gordini turbo carb. mine runs great as the one like sparkie had it before me though he ran a charge cooler. in an aid to keep the temps a bit cooler ive increased the size of the main slightly but all the jets in there dont match up with what i was expecting to be in there. its an old car so it is possible it has been changed in the past. im going to throw it on a dyno in the next few weeks and log the afrs to make sure its ok.
Re: gordini turbo carb
I'll go and have a look in a mo......
Can you remember the carb number? 32DIR75??
2 Attachment(s)
This any good? 122b with cj6-turbo.
Cheers bud, it's ment to be a 32 dir 75 but I'm sure mine isn't, I'll check the numbers on the carb but i think mine has a a 23 and 24mm Venturi
I found it based on the jet sizes in some old coupe documentation, not sure what car it should be on but I have it listed as a weber 32 dir 107 fitted to a r5 alpine turbo 84à laureate? But it has the same Venturi and jet sizes as mine
Laureate turbo is what the french call your car.....
winner in french? thats cool, just good to know whats in there, as i thought it had some mad miss match of jets in there. turns out they are as specified from factory bar the one you changed
