i have a prob with my engine which is when it starts to warm up the engine cuts off as if you have switched the ignition off when you havent, has anyone had the same problem or have any ideas
forgot to say when it goes cold it starts and runs till it gets warm again
Mines doing this, any ideas?
Only thing that's got me stumped is the coolant temp sensor, where is it?
lol i shouldnt presume everyone has a c1j.
Coolant temp sensor is in the head this gives the ecu the signal. Check icv if you have it in. What is the maf adjusted to? Sounds like it is dying when it comes off choke
Side or front?
I've got a 2pin (like an injector) connector on the front (flywheel end) but it looks more like a knock sensor then a single pin one on the end of the head above the thermostat housing (which looks more like a temp sensor) but my loom doesn't seem to have a connector to fit it?
