hi i thought i would put up some pics of the start of my efi conversion first stage engine out gear box split engine on stand work time 5 hours
hey man you could try uploading your pics to photo bucket and hotlinking them, http://www.dtdirl.com/forums/showthread.php?t=15189
shouldnt be too long now with it
you can download photobucket for your phone to save on dongle usage and then follow the instructions on that link :)
well nearly there . car is of for rolling road to be set up first week in feb cant wait
Wow, quick work!
good work Jock !
the yellow pipes make it look like a snake pit!:eek:
Looks awesome;)
Who's mapping it?
thanks mike ye its an eye full for sure !running a tuber manifold has led to the end of the fuel rail being very close to number one tube about 10mm clearance bit of a concern but have a couple of options will keep you updated . you might want to check with other future sales what manifold there using ?just thought you should no if you didn't already. of to rolling road first week in feb for mapping cant wait thanks again
try and make a small heat shield for it......the ex manifold will certainly glow!!:crap:
you could wrap that part of the exhaust pipe and get a fluro-lined 8mm 90 or 145 deg pipe from samco......plus a heat shield.....if its still a prob you can send me back the rail and i'll make you a new one with a banjo fixing on it instead of the tail!
