I have some,I got them for modding Dini engines but have learned that its the GT turbo boys that make better use of them:confused:
If this is so can I be pointed in the right direction?
They're far too small, too much work in modifying them to fit aswell.
isnt the gt17 a td unit?
I think they are smaller than a standard T2 if my memory serves me right:)
I dont doubt what you say,however the feedback that Ive had is pretty much 50/50.They are interesting little units.
Howabout this then,small enough to fit 2 maybe? Hmmmmm
(strokes beard and has nother puff:smokin:)
They're a 120hp (at a push) rated blower. Waste of time going through the aggro of getting one to fit.
The Garrett website rates them at 175bhp in standard form and it is fitted to the BMW330 diseasel
Don't they get fecked quite quickly by heat as well? Not what you'd want on a GT engine:coffee:
All the cars that, that turbo is fitted to........if its the basic gt1749 vnt :D
http://www.turbo-product.com/Garrett/GT1749V.ASP
in a 147 as well:laugh:
I think we'd need to know the sizes of the wheels in that turbo, from what I can see there are 13 possible compressor wheels, and 3 possible turbines. Some are smaller than the standard 5 turbo, and some are a bit bigger.
Std GTT T2 turbo
compressor 48mm exducer, 33.95mm inducer, 50 trim
Turbine 47mm inducer, 35.25mm exducer, 56 trim
You can pretty much tell compressor flow by the inducer diameter, ie 33.95mm
For the GT1749V
compressor 49mm exducer, inducer between 32.9mm and 38mm
turbine 43mm inducer, 35.5 to 36.6 exducer
To put that in context, a T25 with a 60 trim compressor will have a 42mm inducer.
more info needed...
Get a GT2559 off the Espace/Velsatis.
60mm compressor wheel, T3 sized cover, 54mm turbine wheel.
Dave, are they the ones with the twin oil/return feed, V6 job?
Bearing housing shot would have helped jog my memory. They've got a Toyota style core, oil feed from the bottom (which is a twin feed pipe, hard to explain) and a drain right next to it. A massive pain in the arse...
I first sold one to Biggs a year or two ago...
I guess not, you've got to find the adapter to start with. I've chucked quite a few away aswell:D
Apart from that, you need to precisely drill new positioning holes for the vnt, modify the manifold, modify the water lines, modify the elbow, and find a blanking plate for the ecu plug on the top of the actuator. They also run about 18psi stock.
I just remembered, the actuator would sit practicaly on the manifold with that turbo, impossible to rectify, so not suitable.
True, but you would have hell of a spec standard VNT.
Its basically a T28 spec turbo innit, with VNT. Even the ex housing fully opened is 0.64 AR IIRC..
There's a wall on the bearing housing, i'm not sure if the actuator arm would clear it. Does the wrap not absorb the heat too?
http://cgi.ebay.fr/BMW-E46-TURBO-GAR...d=p3286.c0.m14
If you are unable to view it,it maybe this new ebay system that prevents you from looking at foreighn listings.Im in France and so is the listing which is why I can look at it.Its a stupid rule,the seller now has to pay a fee to become visible to overseas bidders.
Cher membre,
Malheureusement, l'accès à cet objet a été bloqué en raison de restrictions légales en vigueur dans certains pays. Conformément à ces restrictions, nous nous efforçons de bloquer l'affichage des objets concernés. Nous regrettons de vous informer que pour des raisons techniques, certaines annonces ne rentrant pas dans le cadre de ces restrictions peuvent ne pas être accessibles aux utilisateurs. Nous vous prions d'accepter nos excuses pour tout désagrément et nous espérons que vous trouverez d'autres objets intéressants sur eBay.
Merci.
Cliquez sur le bouton Page précédente pour revenir en arrière.
