Can someone post an AFR target table?
I'm interested about the cruising targets you use.
I'm using MS2.
Thanks
I'm using MS2.
Thanks
cruising could be anywhere between 14:7 and 15,5-16 depending on how the engine will react :)
I have tried 15,5-16 but then the EGT was a bit high.
My sensor is just behind the turbo and I have seen 750-760C.
By the way, what should be a normal EGT temp?
I can't comment on normal but max shiuld be around 950-1000
I think it is way to much. And really depends where is it measured.
So really would like to see some AFR targets and some EGTs from all you c1j EFI users. :D
Depends on your ignition timing too, if it's too retarded it will have high egt's either way
Would be glad to see other ignition tables too. ;)
Wasn't there the standard ignition map/table posted up a couple of years ago somewhere?
Was there also some information in the Xenon 'Upgraded AEI' product thread?
Might be worth a search.
I think I have seen those.
My focus is the AFR target and EGTs people measure.
But I'm really glad to see other ignition tables. How much they have changed the standard table.
It is hard to find anyone here in Hungary who has experiences with c1j EFI, :D
:agree: sorry that I can't help you any further. Maybe you could ask Scoff if he's willing to send something over ref AFR and EGT??
I'd only like to double check if my afr targets / egt measures are good / safe.
Or I'll ask Scoff if he could travel here to Hungary for a fine tune. :wasntme::wasntme:
Anyone with an AFR target table lying around? :D
Or some EGT values...
Here's Scoff's Version 'D' std AEI ignition map.
https://www.rtoc.org/files/Technical%...ff/gtt-map.jpg
I just inputted everything manually and then tweaked the idle to get it stable. I'll try to dig out my map so you can see the tweaks.
Woz
Here's a picture of my ignition map. For those that don't know, I'm still running a Carb at the moment and using my MegaSquirt MS1 Extra to control the spark only. In essence, the EFI bit is still running, it's just not connected.
Woz
Nice one Woz :)
Thanks Woz!
I like your idle stabilizing.
I have modifed my AFR. It was quite lean on cruising. High 16s.
I have changed it to high 15s and now car feels much better and even the EGT is a bit lower.
Now I have to play a bit with the acceleration enrichment.
http://www.mgexp.com/article/co-afr.html
this one seems to be fairly accurate.......:):)
I copied the figures for our own purposes and put them in a continuous list:
CO% to Air Fuel Ratio (AFR) Table
%CO - AFR
0.1 - 14.72
0.2 - 14.54
0.3 - 14.42
0.4 - 14.34
0.5 - 14.28
0.6 - 14.23
0.7 - 14.21
0.8 - 14.17
0.9 - 14.15
1.0 - 14.11
1.1 - 14.09
1.2 - 14.04
1.3 - 14.01
1.4 - 13.98
1.5 - 13.94
1.6 - 13.89
1.7 - 13.86
1.8 - 13.82
1.9 - 13.80
2.0 - 13.77
2.1 - 13.73
2.2 - 13.69
2.3 - 13.63
2.4 - 13.59
2.5 - 13.56
2.6 - 13.54
2.7 - 13.49
2.8 - 13.45
2.9 - 13.41
3.0 - 13.38
3.1 - 13.34
3.2 - 13.31
3.3 - 13.27
3.4 - 13.24
3.5 - 13.20
3.6 - 13.15
3.7 - 13.12
3.8 - 13.08
3.9 - 13.03
4.0 - 13.00
4.1 - 12.96
4.2 - 12.93
4.3 - 12.90
4.4 - 12.86
4.5 - 12.83
4.6 - 12.80
4.7 - 12.75
4.8 - 12.70
4.9 - 12.66
5.0 - 12.64
5.1 - 12.59
5.2 - 12.54
5.3 - 12.51
5.4 - 12.46
5.5 - 12.43
5.6 - 12.40
5.7 - 12.37
5.8 - 12.30
5.9 - 12.25
6.0 - 12.25
6.1 - 12.22
6.2 - 12.18
6.3 - 12.13
6.4 - 12.10
6.5 - 12.09
6.6 - 12.03
6.7 - 12.00
6.8 - 11.96
6.9 - 11.93
7.0 - 11.89
7.1 - 11.86
7.2 - 11.82
7.3 - 11.79
7.4 - 11.76
7.5 - 11.72
7.6 - 11.69
7.7 - 11.65
7.8 - 11.61
7.9 - 11.58
8.0 - 11.54
8.1 - 11.50
8.2 - 11.46
8.3 - 11.43
8.4 - 11.40
8.5 - 11.36
8.6 - 11.32
8.7 - 11.28
8.8 - 11.25
8.9 - 11.21
9.0 - 11.16
9.1 - 11.12
9.2 - 11.08
9.3 - 11.05
9.4 - 11.01
9.5 - 10.97
9.6 - 10.94
9.7 - 10.90
9.8 - 10.86
9.9 - 10.82
10.0 - 10.79
Nice one Trev, that's a handy table. Looks like mine is running near enough stoich according to my mot emissions figures.
