Does any body know what pins on the clock power it up as need to test two I have for sale at the moment , don't want to go putting power somewhere it shouldn't be.
I also require this info.
Someone said about using a 9V PP3 battery, but where do I connect it to?
I understand there's four connections. But (if you look at it left to right) which pin does what?
Cheers
Scroll down and the clock pin wiring shall be revealed!
https://www.rtoc.org/files/?path=Technical Files/Wiring diagrams/
