ok so who knows the wheel fitment of a 21t.
Its 5 stud so not the same as a 5. Does the 21t share wheel fitment with any other Renault?
Ps yes there will be lots of 21 posts now.
You could reduce the number of posts by doing a 5 min search on google first?
PCD 5*108
Standard wheels are 15inch diameter and 6.5 inch wide, offest is ET42 ( I think)
Centre bore is standard Renault 60.1mm
If your going to run 17inch wheels as many people like to do then again you doint want any wider than 7 inches and you want an offset of et35.
As for other wheel some Lagunas, Safrane, some Alpine A610 fronts. Clio V6 fronts. Volvo 850 t5 lots of choice out there. Theres also many posts about this topic on the 21toc boards so I'm sure a search on there would be helpful for you.
Im building a 21, and i would like to know a god fit for on the 21. I only got the original wheels in 5x108. Annyone got pictures of some nice ones on the 21?
http://21toc.com/
Better to ask for some pics on there :agree:
