Re: Rear suspension height
Just measure the distance between hub to arch when jacked up, take the two main torsion bars out.
Jack the rear beam up by how many mm i.e. if the hub to arch was 330mm and you wanted to lower by 30 mm you would deduct 20mm off the first measurement, jack beam up.
Turn torsion bars spline by spline until it fits back in. It will go in eventually.
Do as brigsy says but make sure you un-do the dampers, else the rear arms can hang from them and retain some tension in the bars.
Just need to sort the wheels out which don't fit great anybody got anything
r5turbo2
The more I see of these the more they grow on me :)
:laugh: they are a bit on the ugly side compared to a 5 but I like it
r5turbo2
Far from it bud I'm starting to like them it's probably only the third iv seen think iv seen a black and red one now yours I like it :)
Looking good bud, - arches nicely filled! ;)
Yep I like got a charge cooler to fit next weekend
