Re: 9 and 11 Turbo exhaust
Mr Raider
Does anyone know if the exhaust centre sections are the same on a renault 9 turbo and an 11 turbo? silencer on centre section is mounted across on passenger side in front of rear wheel. I can find a centre section for a 1.7 11, and a 9 turbo just not a 1.4 renault 11 turbo :scratch:
I'd bet there the same part fella, the cars are basically the same
Hmm, well sods law found exhaust centre section on fleabay new for 1.4 11 turbo 183-86 £44 delivered. Now that I want to buy it, its gone, contacted seller and they no longer have stock from supplier :(. The exhaust on car has few small holes, think its been welded before so ideally needs replacing, getting stainless one made not an option due to budget so just need a standard replacement to keep with OE theme.
So you reckon no difference between a centre section for a 9 and an 11? or 1.4 & 1.7? know they are strange shapes due to silencer on centre section being mounted from side to side instead of the convnetional front to back :coffee:
Ps, bushes!!! ;)
Ive interchanged 9 and 11 exhausts in the past. They're the same underneath. If not a straight swap it'd only be tiny adjustments. I bought a 5GTT stainless for mine and it only needed lengthening down the middle bit.
Ah cheers Dave,- good to hear! was it pattern part exhausts, or aftermarket you swapped over?
Mr Raider
God knows, its a few years ago now!
I have a side exit for a R11 turbo in stock, if that is any use?
Thanks
Mie
Ta Mike, will bear it in mind although its very oe so trying to keep it all original :)
