MK1 Clio 16v dashboard into Renault 5 - fitment guide
Please can someone post this in the articles section
all pictures are in here: https://www.rtoc.org/boards/album.php?albumid=1229
You will need:
clio dashboard and centre console
clio non PAS steering column to match your rack (square or spline)
clio ignition barrel and key (remote and matching IR reciever if required)
clio steering wheel boss and headlight switch
clio electric window switches
clio hazard switch
clio foglight switches and wiring plugs
3x top dash retaining clips - Part number:
plug/switch wiring:
rear fog:- not used
- cream
- blue
- blue
- brown
https://www.rtoc.org/boards/picture.p...ictureid=13945
front fog- not used
- brown
- blue
- blue
- black
https://www.rtoc.org/boards/picture.p...ictureid=13947
hazard switch- blue
- cream
- red
- green
- purple
- purple
- cream
- not used
- green/red stripe
- grey
https://www.rtoc.org/boards/picture.p...ictureid=13931
https://www.rtoc.org/boards/picture.p...ictureid=13930
Dash Fitting:
Remove the renault 5 dashboard, leaving the wiring loom in place
https://www.rtoc.org/boards/picture.p...ictureid=13916
Strip the clio dash down and remove white heater vent plate and the internal vents that distribute air to the outer vents
Weld in clio column onto GTT column mount - We added extra bars for strength, now when you wobble the steering wheel hard the only movement is in the bulkhead!
https://www.rtoc.org/boards/picture.p...ictureid=13925
https://www.rtoc.org/boards/picture.p...ictureid=13928
Trim top of GTT heater matrix plate as shown
https://www.rtoc.org/boards/picture.p...ictureid=13914
trim sides of dash to remove about 1" of the sides, then test fit dash screwing to bulkhead as shown
https://www.rtoc.org/boards/picture.p...ictureid=13938
https://www.rtoc.org/boards/picture.p...ictureid=13943
run the gtt loom around behind the dash, seperating the bits you will need
wire in hazard, fog switches etc as shown above, using the GTT wire colours with clio switches
the GTT clocks will fit in the space for dials, brackets need to be fabricated for it to mount securely
for the light switches, i used a clio assembly, with clio steering wheel boss so indicators cancelled, clio/r5 plugs are interchangable.
for wipers, i mounted the r5 switch onto the clio bracket, using a machine screw to adjust its placement, and plugged straight into r5 loom. i'm sure you could use the clio switch, but i remember miller saying wiring was a mission
for central locking/cigar lighter i used the clio loom for them and spliced into the gt loom, yellow for power, black earth, blue for the light and the central locking wires are the same colour on the 5/clio
remove plastic covers from r5 dimmer switch plugs, and fit tags onto clio dimmer (i heatshrinked one to stop shorting out)
https://www.rtoc.org/boards/picture.p...ictureid=13935
i put the electric window switches where the rear fog/HRW switch went, and used 2x drivers side clio switches so front windows now have 'one touch' facility
https://www.rtoc.org/boards/picture.p...ictureid=13933
Fit clio barrel into column, as i had an IR remote key, i used the matching sensor so have got remote locking on the key itself
with the aux gauges next to clocks, i made 3x 52mm holes after stripping out the standard 16v gauges, and fitted volt, oil pressure and boost gauges, then refitted the covers so they look OE. made up a wiring loom to plug them into the car and fitted using the clio fixing points
https://www.rtoc.org/boards/picture.p...ictureid=13919
i used a clio heater panel and plug, tapped into the gtt loom, then set blowers to screen, and used the gtt heater temp cable routed from left to right, cabletied onto the mixer bracket so that i can have hot or cold (clio heater panel works opposite to the gtt)
once this is in start adding all the side vents, instruments etc.
top dash will need trimming round the leading edge to fit, as the dash sits closer to the bulkhead than on a clio
https://www.rtoc.org/boards/picture.p...ictureid=13950
with the fusebox, i used the original gtt one, and fabricated brackets to mount it in the standard place, just need 2x strips at the back to support it, and the lower cover will support the front.
https://www.rtoc.org/boards/picture.p...ictureid=14061
in the top left of the fusebox, i added an extra fuse section and wired them all to an ignition live off the back of the fusebox, so i have 6x outputs for gauges etc so everything is fused properly
finished pics:
https://www.rtoc.org/boards/picture.p...ictureid=14980
https://www.rtoc.org/boards/picture.p...ictureid=14979
https://www.rtoc.org/boards/picture.p...ictureid=14978
big thanks to miller as well, as he was the one that helped me do mine in the first place :agree:
Re: Clio dash fitment guide
just waiting for a nice day to get the car out the garage and get a few more snaps... is there anything that looks like i've missed out on the guide?
Great work mark :agree:
thanx buddy this going to help me alot :)
pics are shocking!! iphone camera is poop!
car is now at my unit, so can finish off the pics and guide by end of week...
Brilliant write up mate, i've been fitting my clio dash over the weekend and pretty much done what you did except i made new bracket for steering column so i can change column if needed.
Helps out on wiring too, was thinking of using clio loom but went against that, least the plugs aren't too bad to swap over.
Markey Mark (BD)
i was going to use clio loom too, but miller was the one that said about changing the plugs :smokin:
also was going to wire in clio fusebox but with the addition of the extra block of fuses the r5 one actually works better
One question with the plugs you showed mate, what colour wires on the 5 loom match up to the wires on the clio plugs?
sorry i probably didn't make it very clear, colours are for r5 into clio plug, so clio colours are irrelivant as i've used the r5 wires straight into a clio plug :agree:
markey b
Ah i see mate, so the colours you listed are the colours of the 5's wires fitted to the clio plugs, got it now :agree::)
I'm just in middle of doing my 5 loom so was little stuck on that bit :laugh:
Markey Mark (BD)
yup :) my fault for being crap at wording things like that :laugh:
any chance this is gonna go into articles?
hey man any joy on the pictures?
robx1r
yes fella i've found them on my laptop, just need to re-host them and slot them in order
Thanks man I want to try get it on the road before christmas
