r9 lowering??? is the suspension the same as the 11???
not sure but are the front and rear shocks the same as the 11 turbo???
Re: r9 lowering??? is the suspension the same as the 11???
yes :) 19 16v rear struts fit too (stiffer) but they are longer so if you're lowering it too much they won't fit...
Tutuur
legend ;)
experienced by myself :laugh:
r5_scotty
:coffee: where you going with this lol :D
Nick k
you know matey:agree:
r5_scotty
Tutuur
I wondered but never knew for sure...cheers!
Although, I have enough performance kit, would like to stick my 9 on airbags so I can SLAM it :P
Only have to press out the bush at the bottom, it's smaller in diameter than the 9/11 shocks.
The problems i found when going lower where the front stabilizer hitting the subframe and the driveshafts fouling the beams.
This is subframe on ground territory though :D
