Oil Filter; which one for the 5GTT C1J engine?
Hello Folks,
This topic in the Articles section is a subject that I've long been researching an
answer to, particularly as some of the "popular" marques are seemingly no longer
manufactured and fetching quite spectacular and stupid prices. The price of oil filters
is going so far north it's becoming a cheque-book sport. For what is nominally a
simple service item, that's just daft. The whole point of these parts is that they are
changed properly and frequently.
So, as the owner of a 2L petrol turbo Renault I was rather surprised to find that
the oil filters for the F4R engine have more or less identical dimensions as those
fitted to the smaller, historical C1J engine. I've broached this subject here before,
only to find objections because of presumed "oil pressure loss". To be honest, I
didn't buy those arguments then and, having done more research since, I certainly
don't buy them now.
If it means that I can replace the oil filter at frequencies of at least twice or more by
using one that has been developed for the modern era, that is for engines (and oil)
developed long after the C1J went out of production, then so be it. The idea that we
be tempted to "stretch" the life of filters that were previously specified because of
cost or rarity just becomes daft. So, with this overlap in mind, what should we look for?
Well, it's very simple, although finding the evidence for this simplicity has not been
at all easy. The first bit of research is in oil pressure measurements. The absolute
critical measurement is that the by-pass valve is not forced to open and let through
unfiltered oil until it's absolutely necessary. Next comes the flow statistics, that is
the filter not interfering with the oil pressure on the exit side. That can fairly easily be
answered by the physical dimensions. In other words, if the enclosure dimensions are
similar, then the flow will also be well within tolerances. Indeed, it could be argued
that flow, at a non-diminishing pressure, will be as good or better with modern filters.
So, it comes down to getting accurate statistics regarding oil pressures at critical
moments and making comparisons. Trying to track these down has not been an easy
job. They are, thankfully, available in tech publications from Renault. For the C1J it
came down to researching period publications. For the F4R they're found deep in the
Dialogys system. So, to the figures...
C1J Turbo
Revs @ 750 rpm (idle) 1.3 bar
Revs @ 4,000 rpm (turbo active) 3.2 bar
F4R Turbo
Revs @ idle 0.4 bar
Revs @ 4,000 rpm 2 ~ 4 bar
What the figures show is that the tolerances of the 8200 768 913 oil filter for the
later Renault engine will happily cope with the C1J engine. So that should make the
market for paying well over the odds collapse. I've discussed this at length with Karl,
my Renault mechanic of many years, and it's quite clear that he won't be screwing-up
his nose at me for substituting them. He's probably more fastidious than I about these
things, so I'm not inclined to ignore his advices at the best of times.
Like me, he's far happier that the filter gets a regular change, rather than sticking to
what is likely to be old technology at what is becoming stupid pricing. This especially
as the specs of the oil have not stood still in the intervening years either.
Regards,
Steve
Re: Oil Filter; which one for the 5GTT C1J engine?
Good research I wish I had seen the posts before, I have been using the F4r purflux oil filter's for a while on my old C1j's and my current F7pt run's one also
Was there any filtration sizes info?
Over the years the talk has been about particulate size.
People have said that when a turbo is fitted, finer filtering is needed to protect the turbos bearings.
Looking at the external size of a filter doesn't tell you anything about particulate size removal. Or flow really. Are there different design approaches from different manufacturers or at different price points?
As far as oil pressure, simply look at the gauge with different filters fitted and note the readings.
Ian S
Info like that is like tracking down specifications for hens teeth.
Ian S
The filter comes from my F4RT engine, which is a Turbo. The oil change period is
every 12 months or 12,000 miles - double that of the C1J so my guess is that
filtering technology has also improved over the past 25 years.
One thing I will enquire about is whether the turbo on the Coupé is oil or water
cooled...
Ian S
Looking at the external size of a filter doesn't tell you anything about... ...flow really.
Flow comparison can easily be determined. Similar pressures through a specific
size of orifice, the inlet holes or the return stub, show that the modern filter has
an almost equal flow rate to its predecessor. The difference in quoted bar pressure
at 4,000 rpm in the F4R tends to indicate a different flow rate may be set for the
engine on overrun. The far more critical thing is that the bypass valve does not
open when the turbo on either car is at full chat.
Obviously, the R5GTT no longer being a daily driver means that it probably won't
be at every 6,000 miles when the oil gets changed. So, if for example it's done at
every 3,000 miles, the cost of the modern filter as opposed to the original has
little bearing on a decision about whether or not to change it. Rarity of an original
filter should not elevate it to some mystical status through some of the silly prices
I've seen of late when equally good, or maybe better, modern service parts are
perfectly good for the task.
Regards,
Steve
Good stuff. This is probably what Purflux have done by superceding the old LS590 with the LS218 which can be bought cheaply.
2 Attachment(s)
Attachment 31029Attachment 31030
Visual comparison of the f4rt and CIJ oem filter.
Matt Cole
Anyone know part no of ls218..renault want long 9 diget no
Think it might be 7700 274 177
A motorfactor might be cheaper than Renault...
Purflux LS218's are 7700 274 177 which are OE filters on Clio 1.8 16V F7P engines. Fram PH5796 are a very similar filter to LS218's. Got a few filters in my stash for the fleet C1J, F4R, & F7P :D
