Need to wire in My alternator can anyone point me in the right direction with a diagram or just tell me what the two wire to the plug go to please
You can use the std GTT loom for the alternator and starter remove everything else from the loom as you wont need it
purple (Dash light),
yellow,(Charge wire)
thick red, (starter, alternator, battery)
white with green stripe (starter exciter),
and of course earth wires
Ryan, why don't you pop up and come look at mine, the car's in bits at mo so all my wiring loom is viewable you may even be able to see anything else you need to :-)
Thanks bud that helps. I'm really busy with work but send me your number in a private message and we will sort out a day
