I thought I'd share how I add long term protection for wheels with you guys with the process and products I use.
I popped round to get some durable protection on a set of new wheels before they go on a car.
Here's how it went.
The wheels are new and have only been on the car to see what tyres it needs and how low the car needs to sit to look right :) So there's only a bit of dust, finger prints and tyre soap to deal with.
http://i59.photobucket.com/albums/g3...psamvyqibu.jpg
http://i59.photobucket.com/albums/g3...psqfgif1zl.jpg
http://i59.photobucket.com/albums/g3...pseuxqptjz.jpg
http://i59.photobucket.com/albums/g3...psi7pob9fi.jpg
They're pretty big. 19 x 9 & 9.5
http://i59.photobucket.com/albums/g3...psjnlkcbis.jpg
To clean them up I used Imperial and a selection of brushes.
http://i59.photobucket.com/albums/g3...psmfufh1d9.jpg
http://i59.photobucket.com/albums/g3...pshrjfx0l9.jpg
http://i59.photobucket.com/albums/g3...pskkqv5isu.jpg
http://i59.photobucket.com/albums/g3...psmajuzaxk.jpg
Thoroughly rinsed before being dried off.
Taken inside and given a good wipe down with Prep. Probably the best smelling panel wipe in town :)
http://i59.photobucket.com/albums/g3...psm9jrwnss.jpg
On to the Rim application. Zero photos of the process as I was on my own and it's a product that needs your attention.
It was great to use. The instruction say to spread it evenly across the wheel and remove after 2 - 5 minutes, while still wet.
With the fiddly design of these wheels, I found once I'd applied Rim to the faces and spokes it was a good time to start removing. Then flip the wheel, coat the back and leave it for a few minutes and remove.
Here's the first coat.
http://i59.photobucket.com/albums/g3...psknmfaljh.jpg
The instructions say to leave an hour between layers so I went and washed the car and gave it a layer of wax. Nice clean new wheels on a dirty car just wouldn't be right.
I came back after just over an hour and got a fresh micro suede and microfiber cloth and got going with the second layer. The second layer went on and off just as well.
I then dressed the tyres with Gyeon Tire.
Here's the results :)
http://i59.photobucket.com/albums/g3...psun19kc1j.jpg
http://i59.photobucket.com/albums/g3...pszehgzz3y.jpg
http://i59.photobucket.com/albums/g3...psuypor7xh.jpg
http://i59.photobucket.com/albums/g3...psbdxobcec.jpg
http://i59.photobucket.com/albums/g3...psjlu4svvs.jpg
http://i59.photobucket.com/albums/g3...psa76marjl.jpg
http://i59.photobucket.com/albums/g3...psg5vindzp.jpg
I hope that's some help.
