I need set of anti roll bar bushes for the phase 1 as they are original and very soft :scared:, any ideas where i can get them from?
Just took a look on our system for inner and outer for them, they are both available from Pearl
Ah cheers bud,what motor factor you work for?
Motor Parts Direct
Cheers mate,called Norwich branch & they cant find in book or on system
They are useless :rolleyes:
have set them straight, got them finding the right part numbers and looking up the right part :crap:
If you contact them again they will sort you out, sorry about that, should have given you the part numbers
PB4261 for inner
PB4517 for outer
Topman, - cheers Dale really appreciate your help :agree: the old girl is getting there slowly lol Cheers Karl :)
Got round to fitting the bushes today, the inners i bought are loads different from the original ones as they are rather flat just with ridges where the clamp goes over :( Anyone else had any issues with 11 inner bushes? Not sure if they are the same as the ones for the 5 :confused:
they should fit fine ;)
lol what the 5 ones? hole is around 23mm, hoping to find rubber ones although will get polybushes if thats all there is
Hopefully get it right, third time lucky. Picked up my special order bushes from renault yesterday and they are wrong! at least i know they are not part no. 7700 789 815 :cry:
Does anyone know the renault part no. for the outter anti roll bar bushes for an 11 turbo with 25mm anti roll bar? not same as the 5 ones as they are not long enough to get the clamp around the recess :scratch:
I'd have a look at 172 poly items mate, yes mine are 23mm jobs but there was a 25mm option. The fitment was perfect. Just the inners to sort :/
Ah, so you did fit the outters then? might look into getting standard rubber outters to keep it original, innners are a nightmare :rolleyes:
Hi. anyone know if poly bushes are available for the 25 Turbo, just starting an overhaul/mild renovation of mine, would be good to replace them while I have the 4 corners off
Hi,
I would call powerflex to see if they do them, from memory they are not listed on their website, are the bushes on 25's the same or similar to other models? need new bushes for my 11, think outters are the same as the ones for a 172 clio or they will fit! ;)
It's for the outer ones. Different part number for the 5 ones, but maybe they would fit ?? ..
Just got these off the microfiche for the inner ones , so may be a little out of date! Two numbers ,for some reason ,first is listed for slightly earlier models.
77 00 789 815
77 00 789 816
good luck:agree:
Top man, - muchos thanks :)
77 00 789 815's dont fit. too big and hole too small for anti roll bar :(
Perhaps 77 00 789 816's are the ones for early renault 11's with larger hole around 24mm :scratch: come on Oli! lol :p
Cheers bud, much appreciated. Are the 816's really slim bushes? as on my 11 there aint much to them at all granted they are 26 years old! :)
I haven't ordered the inner 816 ones, but only two inner types listed for both phases- (815- for 23mm bar) & ( 816- for 24mm bar)
Ahh ok, hopefully there is more difference apart from 1mm in hole bore size, Oli has some 816's on order. Thanks mate :)
816's should be in Tuesday, hopefully fit them saturday
Coolio, please send me a picture bud or post on here ;)
Ok just to confirm, the inner arb bushes part no. ending 816 do fit, they took a lot of brute force to get the brackets on but that's not out of the norm
Nice and snug eh?! bet the anti roll bar cant be pushed through the bushes now! lol
lol you sure they are the right ones?! :laugh:
Cool, ill take a look and get some before I have to stop my compulsive addiction with buying parts for it! :wasntme:
