Hi does anyone know if the Renault 5 GT turbo subframe bolt on to a clio? cheers
Don't think it does mate, bolt holes don't line up and spaced little different.
If you thinking of fitting the c1j to a clio you can use the original clio frame no probs
Thanks alot guys thats a big help. I got a 5 engine and gearbox loom and a front subframe with all the brakes streering rack hubs and suspension. So was thinking of throwing it all in a clio untill the right 5 comes along. The only other worry I is the wiring
Wirings fairly easy to do mate, done few c1j conversions in clio already.
Depending on which clio you buy you can use the original clio brakes, hubs and driveshafts
You will want to use clio gearbox too as this will keep the standard speedo working, the 5 has electronic speedo while clio is cable
Ok. What clio box fits on the Renault 5 engine as i been looking at a mint 1.2 mk1 clio on a R.
Does the car have power steering? If its a manual set up will be easier for the engine change or if it has power steering you can change the set up to a poverty spec manual set up which would be the steering column and rack or just bung the power steering rack up and still be usable.
Ok defo need a 16v box then. Is there anything else that might cause a problem while doing this project
Got a couple of 16v clio boxes if you need one.
I would try to get a clio 16v complete car as it will have the wider front track than a poverty spec clio, thicker driveshafts, rear brake discs already fitted, big comfy seats, better gearbox, 3 oil dials which you can change to 52mm gauges and make it look tidy and keep standish looking.
Also I am not sure if the 1.2 fuel pump would be up for what you need so might be easier fitting an external uprated fuel pump or in my clio 1.8 16v c1j conversion the fuel pump was fine for what I needed.
How much you looking for a box?
£30 collected? Got two to choose from.
https://www.rtoc.org/boards/showthread.php?t=18
Have a look at this article and it may help you:D
Yer I am interested in one. I havent got a motor at the min tho I driving a motorbike. I am going to look at this Clio I want to buy to put my engine not this weekend coming but weekend after as i am very busy at work. The car tax tested and drives. So I will be able to use it collect the box. If you still have them. Hope this is ok.
No worries mate.
Thanks Rich mate. Big help
cheers matt be intouch soon
Does the clio need to be a mk1 or can it go in a mk 2
Mk2 someone has done it in the past with a C1J but to what extent it is different to a mk1 I am unsure. Not sure if the gearboxes are compatable. I know someone fitting a clio williams 2 litre F7R engine into a mk2 clio and the downpipe is hitting the ARB so it might be minimal difference or it could be quite a bit.
i used a clio 16v, best looks, has the handling and brakes to deal with a good powered c1j, although it gets lighter at the front and the nose lifts.. some aftermarket coilovers should be added to the car funds..
bin the abs and make some new lines
you can cap off the pas rack or bin it for another clio manual rack using the rack itself and a steering column extension..
use the clio loom hacked up, its pretty easy to wire up, worse bits the fuel pump wiring but thats not hard if you put your mind to it, simple circuit..
i used a gtt sidey for the exhaust..
use the clio gearbox as said, then the speedo and shafts etc are already sorted..
i put a few pics in my photos so you have look at the room you have.. i remember it being a cnut to do but it was all money problems, i didn't have enough to buy the things i needed.. i got pi55ed off in the end and fcuked it off, but in all fairness the hard work was done and all it needed was making pretty under the bonnet..
problem is you trying to fit stuff that doesnt, making it look right involves tools, a good eye and money.. my intercooler run was sh1t, i hated it.. go oe and really plan for an aftermarket set up or you'll pi55 money away.
go oe all the way in fact, get it all in, working and looking good, then work your was around the engine bay sorting anything that looks wannkk:)
heres the pictures of my clio c1j turbo conversion, old spec can be found under my profile!
https://www.rtoc.org/boards/picture.p...pictureid=5715
https://www.rtoc.org/boards/picture.p...pictureid=5714
https://www.rtoc.org/boards/picture.p...pictureid=5713
https://www.rtoc.org/boards/picture.p...pictureid=5712
https://www.rtoc.org/boards/picture.p...pictureid=5711
https://www.rtoc.org/boards/picture.p...pictureid=5710
Thought id do a post on what i did for mine :)
I used the 1.2 fuel pump and it worked fine ..but i upgraded it to a 16v pump
Subframe wise you cant use the 5 subframe as the front comes up a different way ...clio subframe accommodates the mounts apart from the front gearbox mount ..which you will need to drill a hole in the subframe for :)
My clio was originally a 1.2 ..but i used 16v running gear..front brake setup with some decent pads :)
As for wiring i got miller from here to make me up a working wiring loom using the clio plug ...my third engine conversion was done by markey mark which he used a renault 5 loom on..which im using now.
As said if you need help theres plenty of threads on this forum and a fair few members that have done said conversion including me and reco :D
C1J in a poverty spec mk2 shell would be cool.... I need a project :D
Fancy an R5 project rich?
I finally got engine in and running . I think i haved worked out loom today even got the oil pressure on the renault 5 clocks working
