Fuel tank
Hi.
I have a fuel leak coming from my fuel tank. If you are standing at the back of the car its coming from the right hand side of the tank about half way up from what looks like some sort of bung?
Is there a fix for this?
Or shall I remove the tank for further inspection?
Thanks.
Re: Fuel tank
That's a common issue, the bung (which is actually the end of the baffle) gets old and starts to leak. You can try a seal it up but i tend to swap the tanks with a campus one if its too bad.
Has not baffle inside so no bung, never had an issue using a campus tank before
Re: Fuel tank
Re: Fuel tank
Brilliant thanks for the advice!
