Throttle pump spring. 32DIS 11 Turbo
Hello,
Does anyone happen to have a spare spring that sits on top of the throttle pump tube? I will look around more,but just thought there might be someone one here with one ? Also should it be a fiber type washer around the t/p tube shaft? None of the ones in the kit fitted..
Thanks in advance.
Jack.
Re: Throttle pump spring. 32DIS 11 Turbo
I may have. I have a box of carb parts somewhere that I've not looked in for a decade.
Not sure about the seal.
You are probably the nearest RTOC member to me.
That would be great if you have! name your price... Was hoping to have the car running soon.
I've managed to find one. Thanks again though.
