Vacuum piping - vnt/external wastegate
I have had a search of the boards already, im strugling to see a conclusive answer so as I am yet to run the engine I would just like to see what peoples thoughts are.
I have as follows:
Carb(pre-throttle) -- bleed valve - bottom port ext gate
Carb (post throttle) -- AEI
Carb top -- FPR
VNT actuator -- open
Ext gate top port -- open
Or should I have the top port of external gate T'd into the bleed valve as well, and should the vnt actuator be connected to something? :scratch:
