Re: 21Turbo Track Rod Ends
Can I be a real pain in ass and offer an observation.
If you cut a 2mm slit in the cone it will allow it to tighten even more when bolted down.
That's what I did when I had the GTA ones done .A bit more complicated as they are threaded to adjust for bump steer .
Most effective way is just to hit it with a slitting disc after hardening .
http://i193.photobucket.com/albums/z...6/IMG_1096.jpg
http://www.renaultalpineownersclub.c...ighlight=taper
stu21t
Doesn't need it, they're made to the exact size required :)
