Morning :)
Any idea on rear speakers? i want to put them in the factory location please in the parcel shelf supports.
thanks!
Morning :)
thanks!
Any ideas in respect to what? Getting hold of a pair of OE ones, speaker dimensions, mounting advice, wiring advice, which aftermarket ones to go for?
Searching around it appears the size you want are 10cm (that is, 4 inches). The OE ones are naff so go with decent aftermarket ones, use the mounting screws that come with them and the OE spade connectors.
Looks like there's an absolute ton of speakers on the market. I'd get ones that don't have anything protruding up in the middle in case they foul on the underside of the plastic grille in the parcel shelf mount. If you're into stereo the Focal 100-c look good at £50. If you're not that fussed, there are tons of Pioneer and Sonys between £20 and £30.
