EFI-Parts discounts (Zeitronix, AEM, Adaptronic and some other stuff)
Ok, not technically a group buy, but close enough :)
For those that don't know me I run EFI-Parts.co.uk dealing with aftermarket engine management bits, installations, mapping, wideband and data logging products.
I am the UK distributor for Adaptronic engine management and a UK dealer for Zeitronix wideband controllers and AEM products amongst other bits and bobs.
I have put together some club discounts, so here's a list of prices I can offer to *club members only*:
(they *should* be the cheapest anywhere in the UK, if you find them cheaper, please let me know!!)
Hardware
AEM 6-in-1 UEGO Wideband 52mm AFR gauge kit. P/N: 30-4100. The gauge comes with interchangable facias to create either a black face or white face, and interchangable bezels (black or silver I believe). The come with a Bosch wideband probe and the neccessary wiring - £150 + £7 p&p
http://www.efi-parts.co.uk/index.php?productID=204
AEM water injection kit, complete with pump, 5ltr container, all lines, a progressive (programmable via 2 pre-sets) controller and fitting hardware. P/N: 30-3000. Comes with a selection of jets catering for most power levels - £330 + £8 p&p
http://www.efi-parts.co.uk/index.php?productID=205
Zeitronix Zt-2 wideband/data log controller & multi function LCD display (AFR, EGT & Boost) - £275 + £7 p&p
http://www.efi-parts.co.uk/index.php?productID=173
Zeitronix Zt-2 wideband/data log controller & ZR-2 multi function 52mm gauge (BLUE or RED) - £275 + £7 p&p
http://www.efi-parts.co.uk/index.php?productID=172
or
http://www.efi-parts.co.uk/index.php?productID=171
USB to Serial adaptor - £22
http://www.efi-parts.co.uk/index.php?productID=178
Adaptronic E420c race engine management + 2m bare loom - £550 + £7 p&p
http://www.efi-parts.co.uk/index.php?productID=117
Sensors, etc
Bosch wideband sensor (LSU 4.2 7057 type, to fit most wideband controllers) - £57
http://www.efi-parts.co.uk/index.php?productID=169
EGT probe (standard k-type, 1/8npt thread for manifold) with 8 foot extension - £60
http://www.efi-parts.co.uk/index.php?productID=175
Pressure sender for Zeitronix - comming in the next couple of weeks
Universal throttle position sensor (for logging with Zeitronix, EFI install, etc) - £32
http://www.efi-parts.co.uk/index.php?productID=190
1/8" NPT weld-in boss for EGT, coolant sensors, etc - £6
http://www.efi-parts.co.uk/index.php?productID=176
3 bar map sensor - £35
http://www.efi-parts.co.uk/index.php?productID=120
Trigger wheels
100mm lightened & balanced trigger wheel (36-1) - £18
http://www.efi-parts.co.uk/index.php?productID=220
150mm lightened & balanced trigger wheel (36-1) - £18
http://www.efi-parts.co.uk/index.php?productID=158
7.25" 184mm lightened & balanced trigger wheel (36-1) - £19
http://www.efi-parts.co.uk/index.php?productID=179
C1J crank trigger kit (bracket, sensor & trigger wheel) - £60
Note, now comes with lightened (slotted) wheel and a sensor
http://www.efi-parts.co.uk/index.php?productID=147
I will keep prices up to date by editing this thread.
Everything above and in the shop is in stock, and will usually dispatch the following working day. Prices do not include P&P.
For more information on any of the above you can click the links through to the online shop, or send me a PM or email :)
Anybody wanting to order anything at the discounted prices please PM or email chris@efi-parts.co.uk
You can include anything else from the online shop in your order too, I will discount them where possible.
Now for some pitch!
About Zeitronix wideband
Don't confuse these with plain wideband controllers, they are capable of a lot more than that.
They have inbuilt RPM convertors, EGT, map sensor (boost) input and throttle position (TPS sensor) input.
In short this means that with the additional EGT probe, pressure sender and connection to a throttle position sensor you will be able to display AFR, lambda, EGT and boost on the gauge and using the supplied ZDL (Zeitronix data logging) software you can record upto 9hrs of data from the sensors onto your laptop. For those with EFI cars using a map sensor, it is possible to calibrate the "user" input to log the output from the existing map sensor to save using the optional zeitronix pressure sender.
Ideal for people who tune their own, or others cars. Logs of 1/4m runs or track days can be made to compare AFR with boost, throttle position and EGT values.
A bit about Adaptronic race management
The E420c ECU is a standalone engine management aimed at those who need functions typically required in a race car, but is just as comfortable running a daily road going car too.
For a better idea of it's ability, have a read of the product specification here:
Cheers, Chris
Re: EFI-Parts discounts (Zeitronix wideband & engine management)
good evening you has (I hope for poster at the good places! :ashamed: )
I would be interested (for the moment!!) on this product:
map sensor
on the other hand I would have 2 questions:
1: can you give me the bond of the catch has to buy with!
2: does this product this assemble you it with any type of management?
I am in management sybele challenger 4+
thank you for your assistance :agree:
Hi Xenon
Yes, the map sensor should work fine.
Here is the connector (plug) you need for it:
http://www.efi-parts.co.uk/index.php?productID=130
thank you for the detail!:agree:
no handing-over on this article?
lol :D
if not could you tell me Ci this apparatus French and identical that has Ci, or if its function and all made another thing that there:
Tech Edge 2Y1 : france
Zt-2 & LCD display package : Angleterre
if you assure me that the ZT-2 ace same the functions, to see more, that the tech edge 2y1, I would thus strongly be interested by your products!!
(if the functions are identical at least!!!)
:cool:
Hi Xenon
The functions look similar but I don't think you can connect EGT to the Techedge ? You can see EGT with the Zeitronix. Also, you do not get a gauge with the Techedge, but you get a display or gauge with the Zeitronix.
Cheers
Scoff
Hi Xenon
Cheers
thank you scoff!:cool:
on the other hand I do not hold has to connect the 2 at the same time!!
I wanted to know if yours had same the functions at least, or more function than the techedge!!!
if you me known as that the ZT-2 and better, I would take the ZT-2!!!
except if it makes much less functions!!
thank you, still and sorry for all these questions, but I want what it there ace of better for my management/adjustment! :agree:
Re: EFI-Parts discounts (Zeitronix, AEM, Adaptronic and some other stuff)
A quick update, I have some new things comming from AEM.
The 2 that might be of interest to folk on here are the 6-in-1 wideband kit, P/N: 30-4100 for £155 and their new water injection kit with progressive controller, P/N: 30-3000 for £300. They're not due until the 10th of Feb, but if you Google the part numbers you will find no end of information on either kit. :)
Interesting..
How do you rate the AEM wideband compared to the Zeitronix stuff? as i was looking at the zeitronix lcd ...
I'll be honest chris, I havn't ever tried one, I just needed a moderately priced, high-volume bit of kit that will help me secure the new top-rated-seller status on ebay. General sensus is that they're fine, I can't find many (if any) cases on the web of folk having problems. They're certainly the best selling low-price kit I've come across, by a long shot. They have a wideband analogue output and a serial output, which can be fed into ECU's like the Adaptronic and others for logging or closed-loop tuning.
AEM relented today and decided to ship early, so I should have them in a week or so. I'll stick some pictures up along with a specification. Standard 12 month AEM warranty applies.
aem's are superb,highly reccomended to those that dont like wiring too! as they only have 2 wires to get them set up.
hi chris! have u any discounted prices for the 420d ecu as theres no 420 c on the site:)thanks
