3 Attachment(s)
Oil feed time
Having a few turbo probs lately
so i got a new turbo oil pipe.
when i remove the plugs and crank the engine after it has been sitting for say 5 hours it took 10 seconds
of cranking for the oil to reach the turbo.i've always been aware when changing the oil filter (another horrible job)
that when it was cold it was completely empty of oil so i decided to try and sort this with a megane diesel oil filter
mounting/fitting thingy
after this little attachment its now down to 5 seconds , the filter is also under the alternator and handier to get at!! :):)
Re: Oil feed time
That's a cool mod! Any pics of the actual oil filter adaptor thing? What Mégane is it off?
Two things: theoretically, oil should always be present at the turbo (or within the oil feed) if using the nrv.
Using the correct oil filter with internal valve should also prevent the filter from draining.
Re: Oil feed time
with the NRV oil is in the 6 or 7 inches of turbo feed pipe but the oil gallery and oil filter drain down so they're empty!
the oil only comes out of the pipe when it has oil pressure behind it.
https://www.ebay.co.uk/itm/Oil-Filte...cAAOSwfGpdhd1t
it needs to be modded slightly
i'll try later to upload pics
its a pain when u use a phone as a modem!!
Re: Oil feed time
I don't really remember now, but I don't think I ever waited 10 sec, or even 5 sec, for the oil pressure to rise at the pressure sensor, which was located at the start of the oil feed pipe to the turbo, at the end of the gallery.
As far as I can recall, there was no delay.
Just remembered that, before it stopped working, the gauge would first show the oil level for a few seconds, then the oil pressure.
I didn't get around to fitting an oil pressure gauge just before the turbo so never saw just how much time before the pressure rose.
1 Attachment(s)
Re: Oil feed time
Re: Oil feed time
Thanks Michael ,just purchased one of these housings for my track 5, i'm guessing the protruding finger on rear mount needs trimming back flush?
1 Attachment(s)
Re: Oil feed time
exactly.....
remove alternator and bottom rad hose
also trim 5mm from the big bolt head on the adaptor(to avoid hitting the bottom rad hose) and make a washer at least 2,5mm thick and fit it between the oil cooler sandwich plate and the hollow stud bolt that holds it on:)
youll also have to cut the excess from the new oil pressure switch.....
Re: Oil feed time
Thanks Michael, mine arrived yesterday, i'll take a gander at it soon.
