Volvo Relays
Hi guys,
I picked up a 440 turbo engine ,box,ecus (everything) at the weekend. Ive noticed a possible problem that the loom is cut where the 'red' connector, the fuel pump relay,ecu relay and 2 fuses fit. Im hoping I can wire these up as theres plenty of wire there, does anyone know if the relays are specific or can you use more readily available relays? I assume the fuses wont be a problem does anyone know the fuse rating? Long shot but If anyone has the relays they want to sell please let me know :)
Any help appreciated
Cheers
Steve
http://i34.photobucket.com/albums/d1...psf346721f.jpg
Re: Volvo Relays
try Haz on here hes the best man for volvo loom advice.
Re: Volvo Relays
They're common 4 pin relays, one that comes on with ign to turn on timing ecu, other with thick grey/red wire) turns fuel pump and ecu on during cranking. Both 10a fuses.
Re: Volvo Relays
Thanks Haz ill see what I can get hold of! :agree:
