Does anyone have any idea if you can get coilovers for the r9 or 11?? Do the five gtt ones fit and just change the topmounts?? I know bc do them but there expensive. Any help would be great.
Think i can recall that 5 gt struts are interchangeable so in theory gt coil overs would fit.
From memory..... I think the R11/R9 top mounts are the same as PH1 GTT's but the bearing is under the spring instead of it being at the top under the top mount. Thats not to say GTT items won't bolt straight on, or with a little modification.
This place seems to list them.http://www.evolucion-a.com/en/ecomme...nd-brakes-37/1
Hello,
I've been looking for coil-overs too and came across this company http://www.sobenracing.com
I've looked at cobbling together bits from the R5GTT (front) and R19 (rear), but I think it's all to much of a compromise - so I'll likely order a proper kit from Soben. Best of luck - Mark.
