French Turbo/Turbo 2 forum with online manuals
Like all normal people, I've always had an interest in the Renault 5 Turbo/Turbo 2. I just thought I would share this site I came across while looking for French por.....I mean cars:
http://www.5turbo.org/f39-manuels-de...es-de-rechange
It's a French 5 Turbo/Turbo 2 site, the section linked above has some online manuals in PDF format. I used to work for a French company and always fancied brushing up on my technical French........so I am having a go at translating the Turbo 2 user manual into English.
http://i1322.photobucket.com/albums/...ps1228b750.jpg
Accès au moteur:
Pour ôter les panneaux à l'aide de la clé 5 fixée dans le coffre, sous la tablette arrière droite, manoeuvrez les verrous 4 d'un quart de tour dans le sens inverse des aigulles d'une montre.
Pour replacer les panneaux, pressez les verrous 4, puis tournez-les d'un quart de tour dans le sens des aigulles d'une montre.
Après utilisation, replacez la clé 5 dans sa fixation.
Access to the engine:
To remove the panel with the key 5 fixed in the trunk, under the right rear shelf, manipulate locks 4 a quarter turn in the opposite direction to the pointers.
To replace the panels, press thebolts 4, then turn them a quarter turn in the direction of the pointers.
After use, replace the key 5 in its bracket.
:agree: and so on! Hopefully these are available in English somewhere but anyway giving it a go here :scratch:
Re: French Turbo/Turbo 2 forum with online manuals
i've got most of the manuals with an english translation....
Sparkie
Hopefully not in dodgy pidgin/Google translator French like mine :D
I tried but failed to find any English ones on the net, online or for sale, anyway keeps me out of the pub
jamesy12345
perhaps....... :laugh:
Sparkie
These are a good ones to have a look at:
The 185 hp and 200 hp kits in detail
http://www.5turbo.org/t9315-recapitu...-renault-sport
Tour de Corse 300 hp parts list
http://www.5turbo.org/t9320-pieces-d...-tour-de-corse
Some bedtime reading there :coffee:
i've got....
TDC, Maxi Turbo, Groupe B, Cevennes, MR221, PR1073, 185-200kit, 250 kit + info on bosch cis injection.
Sparkie
i've got....
Nice, not sure if my French (or even English) stretches to that but anyway giving it a go...
http://i1322.photobucket.com/albums/...ps3b4a069e.jpg
http://i1322.photobucket.com/albums/...psf634ab75.jpg
19. Indicateur de la pression turbo
Aiguille dans la 1ere zone: alimentation d'air en dépression.
Aiguille dans la 2e zone (orange): alimentation d'air en pression.
Aiguille dans la 3e zone (rouge): elle ne doit jamais se situer dans cette zone.
19. Turbo pressure indicator
Needle into the first zone: air supply in depression.
Needle into the second zone (orange) air supply pressure.
Needle in the 3rd zone (red): it should never be in this area.
That bit was my favourite so far :agree:
