Re: Wiring in extra speakers
Should be able to connect to the headunit....(should find a diagram to say what wires are the rear speakers) then run wires under the carpet/plastics direct to the speakers.. simples.
No point cutting into the front speakers wires as they will be under powered (IE most stereos are 4x50watts.... if you tap into the front speakers your gonna get 4x25 watt... not the full power.
Cheers Chris, I did think that would happen if I wired them into the fronts. I take it the harness that plugs into the back of the headunit will have the wires for the extra speakers?
Ricardo
Should do.... feel free to send me a pic of the wiring loom and i can tell you what wires are what...
Penfold aka The Dealer
Coolio, I'll try and pop the headunit out tomorrow to get a piccy. I don't think it'll take long to wire them in :)
2 min job if your quick ;)
