Re: F7p fitting idle problem
They tend to idle at 1500rpm after driving if you don't have the speedo cable fitted to the clocks, as there's a road speed sensor that needs to be connected.
If you fit the 16v interior loom and dials along with the cable speedo and road speed sensor you won't have the problem
Chunk
Thanks Chunk,im really trying to keep the gtt clocks in situ if i could and run it correctly
fitting the interior loom sounds like alot of work im bad with wiring lol
There was a few thing's I tried but I can't honestly remeber, you could remove the ICV and block the ICV pipes up so no air / boost leaks then merely open up the throttle body screw a bit once engine warm to allow it to idle around 1000rpm's.
Don't forget to seal up the air bypass screw (like a mixture screw on a GTT, it can pop out after a while) with a blob of THIXO or silicone.
Did we sort it on your car James, I thought we did, like you I cannot remember what we did though
:crap:
5teve L
:crap:
I remember removing the ICV and having it like that for a while, I was looking into something to do with the VSS signal but I can't for the life of remember what I was doing :laugh:
Iirc there only 1 wire that goes from the speedo cable to the ecu, the other 2 are 12v and earth.
Iirc that's indeed what you did mate.
the thing you could do to make it work is measure the block pulse from a clio with an osciloscope to see what it looks like and then reproduce it with a little chip.
Or you could find someone who is able to disable it in the ecu, or use James's option which deletes idle control....
Tutuur
